Electric Hood
Guest ejl
Guest charlie74
highly unlikely,, as most duff pumps would get binned or repaired,, however,, might be worth checking out what other cars use the same style pump as the covers may fit,
whats happend to the old one?
It split at one of the screw lugs. I dont know what the pressure is like in there...its a clean break so can it be Araldited I wonder
Guest charlie74
i would give the araldite a go first,, not as if you have anything to lose, apart from some fluid, i wouldnt think the pressure is too high as its only a tank,, the pressure is most likely retained in the main metal pump section, but dont quote me on that,, lol
Thanks well that will give me some confidence to have a go and stick it!!!
Still, if someone has a reservoir perhaps they can contact me ejlist2008@googlemail.com..thanks
  • 2 weeks later...
Guest siemon
when i got the cabby for the mrs the roof didn't work.When i checked it it was the plastic cap.was broke into about 20 pieces lol.Just spent half the day gluing it all back together,ther was a few pieces missing but only tiny.
I then glass fibred the entire thing.it is now very strong.put it back on yesterday and am going to try and get the oil today to see if it worked.
I cannot not believe that you can not get spares like the cover from ford. They quoted me £1300+ for a whole new pump even thou i only needed a piece of plastic.
Does anyone know who made the pumps as surely they would have this part??
I am really suprised all these years no one has come up with a replacement. They surely must be plenty of them cracked, because I had it crack on 2 different covers I bought. I remember someone posted a link here some years ago to a metal one but was at a steep price of £50 excluding postage. Worst thing about metal you cannot see the level you are meant to fill it up with.
Surely someone on this group must work with someone who does plastics or vacuum forming and could get a set made.
I had try everything on mine in the past 3 years of owning my cabby. Adralite - never worked, superglue - 100% useless didnt work, gasket sealant - only lasted for a few weeks, candlewax - didnt work.
I have now resorted to Tiger Seal PU Adhesive sealant. Panel glue for cars. Hopefully it would work, did it yesterday, so would fill it up with fluid today and see if it would still leak. I really would like a new pump cover, as it has put me off putting my roof down as I rather press a button to put it up and down, rather than manually which I am lazy to do.
Guest charlie74
seeing as the pump repair kit fits the vw pump aswell ,, chances are the vw pumps are compatible too,, and the caps,, just a thought
Does anyone know what kind of pressure is in the oil reservoir? I would have thought Araldite would have held but? EJL
