Guest swampy83 Posted June 17, 2009 Share Posted June 17, 2009 Right as most of you know by know I've bought rambo's mk6 and of course I now have the roof problem (there is a post on this before my time) now he has explained what seems to be the problem i think the quickest way to getting it working is to make a new loom any ideas on how to do this ? All help is welcome and will be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Guest charlie74 Posted June 17, 2009 Share Posted June 17, 2009 yup thanks ) and welcome,, ill go look up previous topic Quote Link to comment Share on other sites More sharing options...
Guest charlie74 Posted June 17, 2009 Share Posted June 17, 2009 have you read the old post? cause a solution was posted there for it, dunno if rambo's tried it though, cabbytech suggested this,, On the Mk 6, cut the blue wire off about 2/3 inches down from the roof switch, isolate the blue wire that was going to the switch, i put mine into a scotch lock and then shrink wrapped it. Then simply connect the blue wire from the switch directly to a good earth point, then you will be able to open and close your roof with the ign on and engine not running or with the engine running..obiously if you want to operate the roof with the engine running, i would strongly advise that you pull over before operating the switch...this cured the problem of the roof not working with the bonus of being able to operate the roof with engine running hope this helps.................. if that doesnt cure it then i would suggest a trip to an auto electrician as most of the other options seem to have been tried, they arnt that expensive and saves having butchered wiring floating about tbh,, but then im not confident with car electrics ) Quote Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted June 17, 2009 Share Posted June 17, 2009 Any possibility this causing an electrical fault to a roof system thats in perfect working order (Tempted) ??? Quote Link to comment Share on other sites More sharing options...
Guest swampy83 Posted June 18, 2009 Share Posted June 18, 2009 have you read the old post?cause a solution was posted there for it, dunno if rambo's tried it though, cabbytech suggested this,, On the Mk 6, cut the blue wire off about 2/3 inches down from the roof switch, isolate the blue wire that was going to the switch, i put mine into a scotch lock and then shrink wrapped it. Then simply connect the blue wire from the switch directly to a good earth point, then you will be able to open and close your roof with the ign on and engine not running or with the engine running..obiously if you want to operate the roof with the engine running, i would strongly advise that you pull over before operating the switch...this cured the problem of the roof not working with the bonus of being able to operate the roof with engine running hope this helps.................. if that doesnt cure it then i would suggest a trip to an auto electrician as most of the other options seem to have been tried, they arnt that expensive and saves having butchered wiring floating about tbh,, but then im not confident with car electrics ) Ok thanks I don't know if he has tried this, I'm going to try it sat if he hasn't just wanted to know if there was anything else I can try at the same time I would like to get it working by end of sat if poss Quote Link to comment Share on other sites More sharing options...
Guest swampy83 Posted June 18, 2009 Share Posted June 18, 2009 Any possibility this causing an electrical fault to a roof system thats in perfect working order (Tempted) ??? not a clue mate Quote Link to comment Share on other sites More sharing options...
Guest charlie74 Posted June 18, 2009 Share Posted June 18, 2009 im assuming its set for manual atm? and that you know how to put it back to pump fed/electric? Quote Link to comment Share on other sites More sharing options...
Guest swampy83 Posted June 18, 2009 Share Posted June 18, 2009 I have good news it worked well after looking for about an 1hr for a lose connection that had come lose while were playing with it. But now i have a working roof whoop whoop thanks for all your help :bowdown: :bowdown: :bowdown: :bowdown: :bowdown: Quote Link to comment Share on other sites More sharing options...
Guest charlie74 Posted June 18, 2009 Share Posted June 18, 2009 congrats,, ) Quote Link to comment Share on other sites More sharing options...
Guest rambo Posted June 20, 2009 Share Posted June 20, 2009 bloody thing, glad i got it up and running for you mate, evan tho i havent driven her in nearly a year i still miss it! Quote Link to comment Share on other sites More sharing options...
