Guest scottishstu Posted June 16, 2009 Share Posted June 16, 2009 hi guys looking for some advise: just moved house and the cabby now has a new home in a garage so its time it got some much needed attention which i havent given it so way too long,the problem is ive missed placed the keys,thought that i would have found them when packing up,but unfortunetly didnt,so the question is what do i need or do to get a new key set?is there an ecu on these etc hopefully be a simple fix? ive managed to unlock the steering colum to get it transported so do i need to dill the barrel out? as iam sure you need the key in and turn it on to get the barrel out? thanks stuart Quote Link to comment Share on other sites More sharing options...
Guest scottishstu Posted June 16, 2009 Share Posted June 16, 2009 thanks mate so all i ned is a lock set~? i didnt damage the steering lock just managed to release the wee clip Quote Link to comment Share on other sites More sharing options...
Guest TSR157 Posted June 16, 2009 Share Posted June 16, 2009 hi guys looking for some advise: just moved house and the cabby now has a new home in a garage so its time it got some much needed attention which i havent given it so way too long,the problem is ive missed placed the keys,thought that i would have found them when packing up,but unfortunetly didnt,so the question is what do i need or do to get a new key set?is there an ecu on these etc hopefully be a simple fix? ive managed to unlock the steering colum to get it transported so do i need to dill the barrel out? as iam sure you need the key in and turn it on to get the barrel out? thanks stuart if u damage it i have the casing for a mk4 Quote Link to comment Share on other sites More sharing options...
Guest warlord Posted July 2, 2009 Share Posted July 2, 2009 you could take out the boot lock and get the number off it and get a key cut that way a bit cheaper than buying a lock set :msg3: Quote Link to comment Share on other sites More sharing options...
