Guest aishford Posted May 11, 2009 Share Posted May 11, 2009 Can any1 help me .my car drives fine but wen i change down the gears to come to a stop or rev my car wen im sitting stationary the revs go drop down to about 500rpm n it struggles to tick over then it goes fine again and every now and then it will cut out .what could this be .ive replaced the air flow mass sensor and tht didnt help any ideas ??????????? Link to comment Share on other sites More sharing options...
Admin Paul Posted May 11, 2009 Admin Share Posted May 11, 2009 Sounds like the ICV (Idle Control Valve), would help tho if we knew what model and engine you have Link to comment Share on other sites More sharing options...
Guest aishford Posted May 11, 2009 Share Posted May 11, 2009 its p reg 1.8i Link to comment Share on other sites More sharing options...
Guest markeyboy Posted May 12, 2009 Share Posted May 12, 2009 agree with paul on this 1, if it is this that is causing the problem giving it a clean with brake cleaner will normally sort ot out have a look on here on how to take it off clicky Link to comment Share on other sites More sharing options...
