Guest mitch860 Posted April 28, 2009 Share Posted April 28, 2009 Hey all, As some of you may know that i am have difficulties with my MK4 efi Xr3i, It starts up fine but the only way to key it running smooth is to rev the nuts of it. If i try keepin the car at a normal speed she seems to struggle as if she aint gettin enough fuel thou when not revin the hell out of her! Ive change fuel pump new fuel fliter oil change and filter includin engine clean. Cheaked breather pipes and replace 1 what was split. Also changed the flame catcher/breather flitter on rocker cover case, Had new plugs waitin on leads, :help: any ideas will be helpful as i dont really want to take it to my local garage as last time the stung me 350 for nothing as they cudnt find problem but when they dropped it back to my friend and i took fuel tank down to find a split fuel pipe! many thanks mitch Link to comment Share on other sites More sharing options...
Guest bolf Posted April 28, 2009 Share Posted April 28, 2009 i would guess at the idle stabilisation , iscv valve , do a quick search to find out how to clean it. Link to comment Share on other sites More sharing options...
Guest mitch860 Posted April 28, 2009 Share Posted April 28, 2009 Also it some time's die's when i stoppin in traffic or a lights Link to comment Share on other sites More sharing options...
Guest charlie74 Posted April 28, 2009 Share Posted April 28, 2009 possible it could be faulty power to the injectors,, or a ecu fault,, have you tried swapping them over with known good ones? or wiggle the leads to the injectors,, had a duff one on a maz once,, similar issues Link to comment Share on other sites More sharing options...
Guest mitch860 Posted April 28, 2009 Share Posted April 28, 2009 (edited) I would ttrythis but dont know any in norwich with same efi lump as mine or in matter of fact another cab driven in norwich! well i do but very rare! so aint possiable yet! Edited April 28, 2009 by mitch860 Link to comment Share on other sites More sharing options...
Guest mitch860 Posted April 28, 2009 Share Posted April 28, 2009 Hmm ok i have dissconected my Vacum pipe to the MAP and also disconnected the Throttle postion sensor and she run's fine but connect one or other and same problem! should i replace both? ? Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted April 29, 2009 Share Posted April 29, 2009 i had this problem too but only when cold, mine was just the throttle position sensor. you sure that it doesnt run right with tps disconnected and map connected??? Link to comment Share on other sites More sharing options...
Guest barryd Posted April 29, 2009 Share Posted April 29, 2009 Fuel filter? Could be starvation - so maybe check the routing of the pipe? Link to comment Share on other sites More sharing options...
