Guest TSJ Posted April 4, 2009 Share Posted April 4, 2009 Does anyone know if it is possible to get a replacement circuit which connects the 3 bulbs that light up the heater blower switches. I managed to get a replacement centre dash from a scrap yard but that circuit is knackered as well. Any tips on how to get the bulbs working again would be helpful. The only bulb that lights up is the temperature one. Inoticed that the circuit board is thin and just glued on, hence asking if it is easy to get a replacement. Thanks in advance for any help. Link to comment Share on other sites More sharing options...
Admin Paul Posted April 4, 2009 Admin Share Posted April 4, 2009 I doubt you would get a replacement pcb. Can you not solder a wire across the broken track? Link to comment Share on other sites More sharing options...
Guest nick Posted April 4, 2009 Share Posted April 4, 2009 i just bought a complete centre piece off ebay and it had the wiring part inside the plastic as opposed to the green flexi bit on back maybe this was off a later model ?? seems like it would be alot more reliable this way there are a couple on ebay at minute just get the seller to send you pic of back and see if its the newer spec hope this helps Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted April 4, 2009 Share Posted April 4, 2009 TSR, if you want send me your heater lighting pack in a Stamped Self Addressed Envelope and i'll fix it for you !!! :icon_salut_gb: Link to comment Share on other sites More sharing options...
