Guest enzodj Posted March 22, 2009 Share Posted March 22, 2009 (edited) Hi, I have a problem with my roof, it just doesn't seem to open or close fully, i've taken some pics to help me explain. As you can see the the rear frame is catching on the plasic mouldings for some reson, when pushed into the retaining clips its near imposable to get it out again. When the roof is being closed the roof latches don't seem to match up, it seems like I need an inch or more to make it close. Any help would be much apreciated as I live in london and its not the nicest part and i'm having to leave the roof open at the moment. Edited March 23, 2009 by enzodj Edited for Text-Speak and Spelling !!! Link to comment Share on other sites More sharing options...
Guest enzodj Posted March 22, 2009 Share Posted March 22, 2009 (edited) Heres a pic of it from the outside, as you can see its quite visible to car thiefs. As you can see I need a new roof but funds are tight, this ones going to have to do for now unless I can get it fixed for the time being. Edited March 23, 2009 by enzodj Edited for Text-Speak and Spelling !!! Link to comment Share on other sites More sharing options...
Guest SiV6Si Posted March 22, 2009 Share Posted March 22, 2009 The roof at some stage has been removed, You need to remove all the rear panels and trims, Check the 3 17mm bolts that fix the frame to the car. I had this problem until i reset the pivot points by undoing and retightening the 3 bolts. After that it didn't touch. Link to comment Share on other sites More sharing options...
Guest enzodj Posted March 22, 2009 Share Posted March 22, 2009 (edited) Thanks mate, i'm going to try that, i've got a few mates to help force it shut for now, thanks for your help mate. Edited March 23, 2009 by enzodj Edited for Text-Speak and Spelling !!! Link to comment Share on other sites More sharing options...
Guest Eggsy Posted March 22, 2009 Share Posted March 22, 2009 I have a lovely boot spoiler for that car!! lol pm me if intersted Link to comment Share on other sites More sharing options...
Guest SteveB Posted March 22, 2009 Share Posted March 22, 2009 hi mate here is a pic of the three bolts you need to unscrew there not hard to see pmsl but thought this may help you out when you remove the rear card make sure you take the automatic window switch out first and take care where the seat belt is it can be a little weak around there good luck let us know how you get on Link to comment Share on other sites More sharing options...
Guest BAVO Posted March 24, 2009 Share Posted March 24, 2009 Got exactly the same problem, will try what you said ta Link to comment Share on other sites More sharing options...
Guest BAVO Posted March 24, 2009 Share Posted March 24, 2009 The roof at some stage has been removed, You need to remove all the rear panels and trims, Check the 3 17mm bolts that fix the frame to the car. I had this problem until i reset the pivot points by undoing and retightening the 3 bolts. After that it didn't touch. Sorry not quite sure what you mean resetting the pivot points, do you slacken off the 3 bolts and move the whole frame forward ? Any help much appreciated Link to comment Share on other sites More sharing options...
Guest SiV6Si Posted March 24, 2009 Share Posted March 24, 2009 take of both rear cards. You will see the 'bracket' the roof Pivots on, it is held to the car via 3 17mm bolts, If you slacken these off and then close the roof ( lock it down to its windscreen catches ) , this will 'reset' the pivot points for the frame. HTH Link to comment Share on other sites More sharing options...
Guest BAVO Posted March 26, 2009 Share Posted March 26, 2009 Hi did what was suggested on here and slackened of the 3 bolts, but there is no movement in the holes ( the holes are the same size as the bolts ) so didnt make any difference, tried disconnecting the rams and pulling the hood up by hand still no joy. also reconnected the rams and undid the tap on the pump and pulled up up by hand still needs to go another inch before the pins sink in the windscreen holes. Any more ideas guys as desperate Link to comment Share on other sites More sharing options...
Guest charlie74 Posted March 26, 2009 Share Posted March 26, 2009 undo the bolts compleatly and fasten at the front and then see if the holes will line up at the back, good dose of wd40 on the hinges wouldnt hurt,, also try when its been in the sun as that will make the vinyl more plyable,, other than that im out ... Link to comment Share on other sites More sharing options...
Guest BAVO Posted March 26, 2009 Share Posted March 26, 2009 undo the bolts compleatly and fasten at the front and then see if the holes will line up at the back, good dose of wd40 on the hinges wouldnt hurt,, also try when its been in the sun as that will make the vinyl more plyable,, other than that im out ... Yeah will try that ta, anyone have a teleport to bean me to the Sahara Link to comment Share on other sites More sharing options...
