Guest davidacr Posted March 16, 2009 Share Posted March 16, 2009 hi, I've just bought a 1993 Escort cabby and the roof wont work. There is no power going to the switch, does anyone know what it could be, or where the fuses, relays etc might be. Also, the rear windows dont have power going to them either, not sure if its related in some way but thought i would mention it. Any help would be good! Thanks! Link to comment Share on other sites More sharing options...
Guest sean1379 Posted March 16, 2009 Share Posted March 16, 2009 Hi there, What Mk cab is it? Link to comment Share on other sites More sharing options...
Guest davidacr Posted March 16, 2009 Share Posted March 16, 2009 its a mk5, 1993 on a K plate. Link to comment Share on other sites More sharing options...
Guest sean1379 Posted March 17, 2009 Share Posted March 17, 2009 There should 2 relays in the boot and a thermal cut out fuse. also there is 2 relays in the drivers side footwell under the kick panel. Have you tested the switch? Link to comment Share on other sites More sharing options...
Guest davidacr Posted March 17, 2009 Share Posted March 17, 2009 thanks for that! We've done some rooting around at the fuse box, and it appears there used to be a toad alarm fitted and someone has removed it but cut the wires for the roof and windows at the same time! So it'll be a quick fix and jump the wires back together and we'll be away Link to comment Share on other sites More sharing options...
Guest sean1379 Posted March 17, 2009 Share Posted March 17, 2009 No probs glad you go it sorted. exactly what someone did before i brought my cab. Link to comment Share on other sites More sharing options...
