Guest trueiron Posted March 16, 2009 Share Posted March 16, 2009 Hi All Have a slight problem with my wifes 1.8 Mark 5 Cab In traffic it is getting warm and the cooling fan is not kicking in I have changed the Fan Switch this morning and still no joy I understand you can short the fan to work all the time - this would test the actual fan I suppose. Can anyone give me an idiots guide to doing this - am about as machanically minded as your average frog Shane Link to comment Share on other sites More sharing options...
Guest Jamiepc Posted March 19, 2009 Share Posted March 19, 2009 Hi All Have a slight problem with my wifes 1.8 Mark 5 Cab In traffic it is getting warm and the cooling fan is not kicking in I have changed the Fan Switch this morning and still no joy I understand you can short the fan to work all the time - this would test the actual fan I suppose. Can anyone give me an idiots guide to doing this - am about as machanically minded as your average frog Shane Hello Shane, take the plug off of the the fan control switch and run a wire from one hole to the other (on the plug), this will short the fan to be on constantly. I would also advise you to check the fuse box to see if the fuse has blown for this circuit and not rely on this as a permanent fix. Good luck mate J Link to comment Share on other sites More sharing options...
Guest Justin Posted March 19, 2009 Share Posted March 19, 2009 Is your thermostat working and known to be good? I had a similar problem with my old Astra, and it was the thermostat reading wrongly and not letting the fan come on.. Link to comment Share on other sites More sharing options...
