Guest BAVO Posted March 3, 2009 Share Posted March 3, 2009 Hi was wondering if you could help, my horn is not working, there is no power to the button, checked fuses all seem ok, horn works from direct wire to battery Any ideas Ta Steve Link to comment Share on other sites More sharing options...
Guest dansankey Posted March 3, 2009 Share Posted March 3, 2009 check all the connections from the horn back to the battery and if all else fails run a new fused live to the horn switch inside the steering column Link to comment Share on other sites More sharing options...
Guest BAVO Posted March 3, 2009 Share Posted March 3, 2009 check all the connections from the horn back to the battery and if all else fails run a new fused live to the horn switch inside the steering column Many thanks mate, just wondered if you know exactly what fuse number the horn is on the Mk 6 as there is no picture on the back of the cover that shows the horn ? Link to comment Share on other sites More sharing options...
Guest BAVO Posted March 4, 2009 Share Posted March 4, 2009 Sorted thanks had to put a push button in the dash for the horn as the steering terminals were f***ed Link to comment Share on other sites More sharing options...
