Guest cossiemark Posted February 17, 2009 Share Posted February 17, 2009 (edited) right dropping a fez turbo engine in the cab its running mfi at the mo got everything i need for the conversion that was until i was told i needed to change the fuel tank to 1 of a escort running an efi engine is this true or can i use the tank and fuel pump from the efi engine??? cheers mark Edited February 17, 2009 by cossiemark Link to comment Share on other sites More sharing options...
Admin Paul Posted February 17, 2009 Admin Share Posted February 17, 2009 You dont need to change the tank or pump m8, leave the MFI one in. If you are going to be running a lot of power you will need to upgrade the fuel pump anyway to a RS Turbo or cossie one. Paul Link to comment Share on other sites More sharing options...
Guest cossiemark Posted February 17, 2009 Share Posted February 17, 2009 sorry meant can i use the tank and fuel pump from the mfi engine??? Link to comment Share on other sites More sharing options...
Admin Paul Posted February 17, 2009 Admin Share Posted February 17, 2009 Just use the one you have on the car mate, if you are going from MFI - EFI then use the MFI one. paul Link to comment Share on other sites More sharing options...
