Guest charlie74 Posted February 2, 2009 Share Posted February 2, 2009 ok done a quick search but most referered to the sender switch,, what i need to know is do you have to drain the system to change the thermostat itself? cheers charlie Link to comment Share on other sites More sharing options...
Admin Paul Posted February 2, 2009 Admin Share Posted February 2, 2009 You do not need to drain system, just change and top up Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted February 2, 2009 Share Posted February 2, 2009 IIRC its at the base of the rad so once its started unscrewing you loose the water mate i'm affriad, be a cheap skate and put a washing up bowel under it when you do it and put it back in when your done !!! Link to comment Share on other sites More sharing options...
Guest charlie74 Posted February 2, 2009 Share Posted February 2, 2009 cheers for the replys,, figured you didnt really need to,, but was one of the haynes manual instructions,, bit like disconnect the battery etc,, ) Link to comment Share on other sites More sharing options...
