Electric Aerial
Guest sean1379
Guest sean1379
Hi there,
I have just replaced my electric aerial(like for like from another cab).
But i have a problem the relays are clicking but no movement on the aerial.
Does anybody know which wire i have to come off on the stereo to trigger it.
Many Thanks
Sean
Guest markeyboy
if it is a after market stereo that you have fitted it should be the blue wire from the stereo (can somtimes be called remote or att)
for the wiring for a std stereo itl probably be best to look in a haynes manual
Guest sean1379
Thanks for the replys.
its a aftermarket stereo. there is a loose blue wire with antenna on it but i am unsure as to where i should be connected to.
Thanks
sean
Guest markeyboy
i would have thought that blue wire should be connected to the coil of the relay,
you say you can hear a clicking when the aerial is supposed to move
have you got 12V to the relay contacts? (you should have this regardless of weather the aerial is up or down)
and a good connection from the aerial to the earth of the car?
Guest sean1379
Hi,
right i have the blue wire coming from the stereo which says antenna -
just need o know what wire/wires this needs to be connected to on the the loom.
am i right in thinking the aerial has a switch live and a perm live to it???
Thanks for you help guys
sean
Guest sean1379
hi.
i have managed to sort it.
like a numpty i am the fuse was missing by the relay.
popped one in and off it went.
thanks for all the replies.
thanks sean
