Engine Missfire Only When Warm Mainly On Low Rev From Idle
Guest paulsteveo
Guest paulsteveo
as above when the car is started from cold revs fine , but after say 20 mins of driving if i sit there and rev say upto 2000rpm it coughs splutters in some cases backfires ,
ive changed water cold start new air filter and oil any ideas cheers paul ??
Guest charlie74
sounds like the ignition leads are breaking down underload when warm,, or possibly a hole in one of the airpipes,,
does it run lumpy like its dropped a cylinder when it does it?
Guest paulsteveo
no it doesnt which is wierd
only when you rev it ,, i cleaned the plugs up but might be worth changing them instead , and leads as well
Guest charlie74
certainly wouldnt do any harm,, other than that im not sure what the fault could be,, have you cleaned inside the dizzy? and replaced the rotor arm?
