Guest busadaddy Posted January 6, 2009 Share Posted January 6, 2009 hi am gettin a full set of rs decals hows best and easiest to fit them cheeRS andy Link to comment Share on other sites More sharing options...
Guest charlie74 Posted January 6, 2009 Share Posted January 6, 2009 carefully,, and with a soft squeege and a sponge,, also use a lil water and washing up liquid and apply the decals to a clean wet area,, then using the sponge work gently from the middle outwards to get it " stuck" the washing up liquid means you have a lil wiggle time to correct the alignment,, then finally go over with the squeege , not to hard as you dont want to tear or move it,, best thing is to whack fitting custom graphics into google and theres bound to be a guide with pics etc,, its not hard,, but time consuming and check everything twice as they are next to impossible to remove and refit,, also you might benefit from waiting till the weathers warmer,, not sure ,, Link to comment Share on other sites More sharing options...
Guest busadaddy Posted January 6, 2009 Share Posted January 6, 2009 cheers mate thanks for your help Link to comment Share on other sites More sharing options...
Guest charlie74 Posted January 6, 2009 Share Posted January 6, 2009 pleasure m8.,,, should look great when youve done it,, if your not sure it might pay to have a chat with a local signage company,, they might even fit em for you for a small charge Link to comment Share on other sites More sharing options...
