Guest udders Posted December 28, 2008 Share Posted December 28, 2008 HELP! My roof stopped on it's way up this afternoon! I turned the key off, waited a couple of minutes and tried again. It closed a bit more then stopped again! Turned it off and on again and it closed! Thank goodness. Any one got any ideas? Is is possibly a pump problem? The rooflight dimmed slightly when I pressed the button so it looked like it was trying to power the pump but it didn't make any noise or move! HELP! Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted December 31, 2008 Share Posted December 31, 2008 It could be a motor problem, try opening the manual key, and then press the rof button, does the motor continue to run or does it stop again ? also what condition is your battery in ? is it starting the car ok. Link to comment Share on other sites More sharing options...
Guest BAVO Posted March 12, 2009 Share Posted March 12, 2009 I had the same problem, it was cured by changing the fuse from 20 amp to 30 amp as its a thermo fuse and as motor ages it takes more effiort to run thus thats why the fuse cuts out Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted March 12, 2009 Share Posted March 12, 2009 The Cog might be on its way out, there is a repair kit in the Club Shop !!! Link to comment Share on other sites More sharing options...
