Guest IanA Posted December 21, 2008 Share Posted December 21, 2008 I've used power steering oil (STP) and having removed the nut, run it down a small screwdriver blade. I replaced the nut and manually raised and lowered the roof a few times to make sure that the level showed "full" when it was open or closed. Roof works a treat now. Cheers Ian Mk5b Si Link to comment Share on other sites More sharing options...
