Guest neiloggy1 Posted December 21, 2008 Share Posted December 21, 2008 managed to get the top panel off so i could get to the blower motor cleard all debris it was easy realy, just remove 4 hidden screws on the panel,undo nescessary wiring on harness and battery,i removed wiper motor for easy access and it just slides out nice n easy,no rust or signs of leaking into car, now i croosed a live wire from battry to blower motor and it works[so it aint the motor???] i then crossed a live from battery to the switch and the fan works[so im guessing the switch is ok] i also noticed no sparks when i crossed live from bat to live on switch so iam now guessing that there is no live feed to the fusebox does ne 1 know what i can do now????? is it possible to make my own live to fusebox and stick fuse on for safe measure will this cause ne problems ?????? i also just noticed rear seat passenger side is wet??? oh no more investigatin lol,neiloggy Link to comment Share on other sites More sharing options...
Guest SteveB Posted December 21, 2008 Share Posted December 21, 2008 hi niel me again !!! lol sounds like your fuse box is gone mate quite common your gonna have to pull it out check the cables in the rear are not melted and that it does not look burnt out i would not try to repair this its prob easier to just replace the box if all is fine i would be led to believe you have a broken cable good luck mate and keep going there worth it Link to comment Share on other sites More sharing options...
Guest neiloggy1 Posted December 21, 2008 Share Posted December 21, 2008 hi niel me again !!! lol sounds like your fuse box is gone mate quite common your gonna have to pull it out check the cables in the rear are not melted and that it does not look burnt out i would not try to repair this its prob easier to just replace the box if all is fine i would be led to believe you have a broken cable good luck mate and keep going there worth it cheers fella how does the fuzebox comeout is it same few clips n screws???? but if its broken cable is this gonna be hard to find??? cheers again for advice,neiloggy Link to comment Share on other sites More sharing options...
Guest markeyboy Posted December 21, 2008 Share Posted December 21, 2008 to get the fusebox out you need to unplug everything, there are a few clips that let the front end drop down then (i think) you unhook it from the rear iv got a fusebox in my garage that came off a 1.8 si saloon if ur interested mate a broken wire can be hars to find, best bet is to get yourself a multimeter and check from end to end, and a haynes manual / decent wiring diagram to help ya find out what colour wires you need to be looking at Link to comment Share on other sites More sharing options...
Guest neiloggy1 Posted December 21, 2008 Share Posted December 21, 2008 to get the fusebox out you need to unplug everything,there are a few clips that let the front end drop down then (i think) you unhook it from the rear iv got a fusebox in my garage that came off a 1.8 si saloon if ur interested mate a broken wire can be hars to find, best bet is to get yourself a multimeter and check from end to end, and a haynes manual / decent wiring diagram to help ya find out what colour wires you need to be looking at ill take fusebox off tomoz check it out already got a multimeter and i suppose colours should be easy to find cheers fella,let you know how i get on tomoz,neiloggy Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted December 22, 2008 Share Posted December 22, 2008 I cant remember now if you have a mk5 or 6 lol, if its a mk5, the wire that feeds the heater switch should be black/red from fuse 14, this fuse is fed from the ignition relay R26. if you have a mk6, then the feed wire should be violet/black, and is fed from fuse 20 in the fusebox, this fuse is fed from the ignition relay R7. good luck, and let us know how you get on.. Link to comment Share on other sites More sharing options...
Guest neiloggy1 Posted December 23, 2008 Share Posted December 23, 2008 I cant remember now if you have a mk5 or 6 lol, if its a mk5, the wire that feeds the heater switch should be black/red from fuse 14, this fuse is fed from the ignition relay R26. if you have a mk6, then the feed wire should be violet/black, and is fed from fuse 20 in the fusebox, this fuse is fed from the ignition relay R7. good luck, and let us know how you get on.. yes its a mk 5 b apparently she has mk 5 front end n dash but mk 6 rear end looks well,and im pretty sure its black/red not gonna get chance to look at it until friday now cos of xmas will let you know how i get on fri cheers for all your help,neiloggy Link to comment Share on other sites More sharing options...
Guest SteveB Posted December 23, 2008 Share Posted December 23, 2008 hi niel good luck for friday where are you from ??? Link to comment Share on other sites More sharing options...
Guest neiloggy1 Posted December 25, 2008 Share Posted December 25, 2008 hi niel good luck for friday where are you from ??? alrite ste ,cant wait till tomoz finally got a replacement key for wheel locks so i can now change my flat tyre[on the road again ] also gonna take fusebox off n check all wires try to get to the bottom of it,lol oh yeh ill need luck lol, im from oldham,manchester up in the hills ne way merry xmas all let ya know how i get on tomoz,neiloggy :big_wave: Link to comment Share on other sites More sharing options...
Guest neiloggy1 Posted December 27, 2008 Share Posted December 27, 2008 alrite ste ,cant wait till tomoz finally got a replacement key for wheel locks so i can now change my flat tyre[on the road again ]also gonna take fusebox off n check all wires try to get to the bottom of it,lol oh yeh ill need luck lol, im from oldham,manchester up in the hills ne way merry xmas all let ya know how i get on tomoz,neiloggy :big_wave: well managed to check wiring today all is ok ,so im gonna have to get a fusebox gonna buy 1 this week as soon as i get 1 let you know if it works thanks for al help again and it is the red/black wire on first row. Link to comment Share on other sites More sharing options...
