Guest neiloggy1 Posted December 14, 2008 Share Posted December 14, 2008 sometimes the temp gauge works sometimes it doesnt, the car doesnt over heat as you can hear fan kik in then cut off any suggestions new to elec problems usually deal with mechanical side of things please help,neil Link to comment Share on other sites More sharing options...
Guest adamk Posted December 14, 2008 Share Posted December 14, 2008 sometimes the temp gauge works sometimes it doesnt, the car doesnt over heat as you can hear fan kik in then cut off any suggestions new to elec problems usually deal with mechanical side of things please help,neil The temp sender might be gone. Its near the fan switch were the termostate goes, and looks like and oil switch. The oil switch is on the back under the inlet manifold, but the temp sender is on front under the outlet manifold. There just a few pounds in most motherfactors Link to comment Share on other sites More sharing options...
Guest neiloggy1 Posted December 14, 2008 Share Posted December 14, 2008 excellent will try that thanks for advice Link to comment Share on other sites More sharing options...
