Guest fudge51 Posted December 12, 2008 Share Posted December 12, 2008 Just replaced my roof but the rear heated window does not work, how do I replace it with the original, Any help please Thanks Mike Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted December 13, 2008 Share Posted December 13, 2008 You will have to start from inside th ecar, and gently start by lifting th erubber all the way around the glass, to start with just tease the rubber away from the frame a bit at a time all the way round, then apply a bit of hand pressure to the glass and start trying to push the rubber up to the glass for want of a better choice of word. Do this the whole way round and eventually the glass and rubber should start to push out of the frame. Putting the glass back in can sometimes be a little trickier, some prefer to use a piece of string around the rubber to ease it back in, but i usually use a bit of fairy liquid, right then, resit the glass into the rubber and place the bottom of it back into the frame, put some liquid around the rubber and get someone to apply a little pressure to the glass while you tease the rubber back into the aperature all the way around, the corners are always a pain, but just take your time and it should come together. finally seal the rubber to the roof and reconnect the heated window wires back up. Link to comment Share on other sites More sharing options...
Guest fudge51 Posted December 14, 2008 Share Posted December 14, 2008 Wow, thanks for that, I think I can practise on the old one 1st, but again you have come up trumps. Thank you and Happy Christmas Mike Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted December 15, 2008 Share Posted December 15, 2008 No problem, you will be an expert yourself soon lol.. Link to comment Share on other sites More sharing options...
