Guest luke88 Posted December 4, 2008 Share Posted December 4, 2008 i have just recently got my hands on a escort cab that has a 1.6 16v zetec engine (90ps) and i was wondering how to get the most of the engine. i have some 130 cams and were wondering if they would fit in please need help too many saxos out there need to go fast!!! Link to comment Share on other sites More sharing options...
Guest Eggsy Posted December 4, 2008 Share Posted December 4, 2008 I very much doubt it m8 as the 130 is a 1.8 - youl probably run the risk of bending the valves on the pistons due to the lift caused by the cam. Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted December 4, 2008 Share Posted December 4, 2008 i have just recently got my hands on a escort cab that has a 1.6 16v zetec engine (90ps) and i was wondering how to get the most of the engine. i have some 130 cams and were wondering if they would fit in please need help too many saxos out there need to go fast!!! Bit if a silly comment to make !!! Just put a 130 Spec 1.8 ZETEC in the Cab !!! Link to comment Share on other sites More sharing options...
Guest mk4stu Posted December 4, 2008 Share Posted December 4, 2008 im a dummy with engines so dont take my word. me uncle had a 1.6 zetec 90 ps he fitted 130 cams, inlet manifold, throttle body and maf sensor or air flow sensor and it run mint for 2 years until he sold it, it did die when the new owner cracked the sump and run it dry as expected Link to comment Share on other sites More sharing options...
Guest markeyboy Posted December 5, 2008 Share Posted December 5, 2008 nice stright through exhaust with decat and a decent induction kit should see a bit of an improvement, failing that it would be a larger engine swap (power to £££'s its a much better option) Link to comment Share on other sites More sharing options...
Guest Alanman Posted December 5, 2008 Share Posted December 5, 2008 I don't know much about these engines so I apologise but just fitting a set of cams out of a bigger engine wont nessesarily do anything at all surely. Just cos its from a bigger engine dosnt mean the cams will open the valves anymore. You need to do everything really, the same as Stu's Uncle did. Link to comment Share on other sites More sharing options...
Guest barryd Posted December 5, 2008 Share Posted December 5, 2008 As our cousinz in the US say - no substitue for cubic inches.... fit the bigger engine. Link to comment Share on other sites More sharing options...
Guest IanA Posted February 12, 2009 Share Posted February 12, 2009 Hi The cheapest way to get a noticeable power boost is to change your oil and add some Activ8. It costs about £25 for 250 ml. Put half in the engine, half what's left in the gearbox and add a few drips to to the grease in the rear bearings. It's only cutting oil and often dissed by oil company people but you'll notice the difference immediately if the oil is hot when you add it. It really made my crossflows and CVH more pokey at the top end. Didn't really notice that on the Zetec, that just pulls better in third. Cheers Ian Link to comment Share on other sites More sharing options...
Guest Michael Tomlinson Posted February 12, 2009 Share Posted February 12, 2009 Hello As Markeyboy says a decent Exhaust and de-cat pipe,Ive put a 4-2-1 stainless manifold De-cat pipe,mongoose exhaust system on mine with a KN induction kit plus a super chip,Next will put a Stage 2 head with a pair or piper fast road cams with veriner pulleys,This is on my Zetec 1.6. Michael Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted February 12, 2009 Share Posted February 12, 2009 Well since FORD FAIR 2008 when I went on the Rolling Road I have improoved the induction set-up and put a new Full-Stainless Exhaust system on it, i'm hoping to improve on the 113.2 I got which wasn't bad as its only supposed to have 115 lol !!! Link to comment Share on other sites More sharing options...
