Guest gav660 Posted November 30, 2008 Share Posted November 30, 2008 hi, my cabby runs really fast while the choke is on then when it switches off the car won't tick over I've adjusted the throttle cable but it keeps winding itself back in an cutting out agian is there anything else I can do to make this a permanent fix??? thanks Gav Link to comment Share on other sites More sharing options...
Guest jay Posted November 30, 2008 Share Posted November 30, 2008 hi, wot cabby do you have? wot engine ? mfi? efi? turbo? xr3i? how old is the car? if you have efi it could just need the idle valve cleaning out, but without knowing which car and engine you have fitted i cant be much help... Link to comment Share on other sites More sharing options...
Guest kafarske123 Posted December 13, 2008 Share Posted December 13, 2008 I't seams as if it's not getting enough fuel, you can try ajustig the fuel mixture, or chek the fuel pump to se that its not failing.not mutch else I can think of right now. sorry Link to comment Share on other sites More sharing options...
