Guest banburycab Posted November 16, 2008 Share Posted November 16, 2008 hi all just up graded my breaks to rs turbo with the abs still in place the discs and pads are new the problem is the peddle seems spongy ive bled them 3 times and its still the same has anybody got any idias or is this normal wit the abs still on . many thanks grant Link to comment Share on other sites More sharing options...
Guest steelcabby Posted November 16, 2008 Share Posted November 16, 2008 DEPENDS HOW SPONGY THEY ARE. IS IT WORSE THAT BEFORE YOU PUT THE BRAKES ON? CHECK FLUID AND THEN GO AROUND EACH CORNER OF THE CAR BLEED THEM AGAIN. IT MAY BE A BIT OF TRAPPED AIR. OR YOU MAY NOT OF BLEED THE SYSTEM PROPERLY Link to comment Share on other sites More sharing options...
Guest banburycab Posted November 16, 2008 Share Posted November 16, 2008 the brakes before were fooked and the pedal was rock hard i used a easy bleed to bleed them ive had it years so mayby that letting air back Link to comment Share on other sites More sharing options...
Guest steelcabby Posted November 16, 2008 Share Posted November 16, 2008 the brakes before were fooked and the pedal was rock hard i used a easy bleed to bleed them ive had it years so mayby that letting air back maybe, try bleeding them the normal way chap Link to comment Share on other sites More sharing options...
