Guest udders Posted November 15, 2008 Share Posted November 15, 2008 Hi all, not so much of a problem but just an annoying one. As standard you have to have the ignition on but the engine off to put the roof up and down. Now, is it possible to re-wire it so you can have the engine running (but obviously not moving) and operate the roof? I find it a pain in the ass having to turn the engine off if you stop at a set of lights etc... to put the roof down. Anybody already done this? Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted November 16, 2008 Share Posted November 16, 2008 I have done it to my last 2 cabs, its an easy mod, i have done it so that i can operate mine with the ignition on and or the engine running, Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted November 16, 2008 Share Posted November 16, 2008 Details ??? Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted November 17, 2008 Share Posted November 17, 2008 (edited) On the Mk 6, cut the blue wire off about 2/3 inches down from the roof switch, isolate the blue wire that was going to the switch, i put mine into a scotch lock and then shrink wrapped it. Then simply connect the blue wire from the switch directly to a good earth point, then you will be able to open and close your roof with the ign on and engine not running or with the engine running..obiously if you want to operate the roof with the engine running, i would strongly advise that you pull over before operating the switch... hope this helps.................. Edited November 17, 2008 by Cabbytech Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted November 18, 2008 Share Posted November 18, 2008 Nice one fella, I shal be giving that a blast !!! :clap: Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted November 18, 2008 Share Posted November 18, 2008 No problem pal, i had to go and check the switch though, because i couldnt remember which wire was earthed out, so i double checked it before posting, let me know how you get on.. Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted November 19, 2008 Share Posted November 19, 2008 Will do buddy !!! :icon_salut_gb: Link to comment Share on other sites More sharing options...
