Guest srmajury Posted November 15, 2008 Share Posted November 15, 2008 is it important to top up your gearbox oil level as i found a leak at the selector shaft and if so is it easy?? Link to comment Share on other sites More sharing options...
Guest Eggsy Posted November 15, 2008 Share Posted November 15, 2008 should be a alan key grub somewhere on the gearbox unscrew it & fill till it starts to come out the box Link to comment Share on other sites More sharing options...
ianxr3i Posted November 15, 2008 Share Posted November 15, 2008 There is a allen nut at the front of the gearbox on the main casing & next to the fifth gear housing. You will need a 6mm or 7mm allen key & as eegsy said Link to comment Share on other sites More sharing options...
Guest steelcabby Posted November 16, 2008 Share Posted November 16, 2008 i third that Link to comment Share on other sites More sharing options...
