Guest Rojar Posted November 10, 2008 Share Posted November 10, 2008 My 97 Mk6 1.8 ghia has a strange idle problem. Starts and runs fine with no problems, pullslike a train etc etc. The problem is sometimes idles at around 1500 revs. A qucik flick of the throttle doesn't settle it down. I have found easing the clutch with the brakes on to drop the revs cures the prblem once the revs drop to nromal idle speed the engine will then idle nromally once the clutch has been dipped. Any ideas? My first thoughts maybe the throttle position sensor is sticking a little. Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted November 11, 2008 Share Posted November 11, 2008 Common prob mate, mine is the same, doesn't stall so I can live with it, just a New Idle Valve required or clean out the old one with Petrol !!! Link to comment Share on other sites More sharing options...
Guest markeyboy Posted November 11, 2008 Share Posted November 11, 2008 as said by charlzy the idle control valve is usuallly the first point to start at, but there are so many things that cause the zetec engine to run bad, have a look on this click, may help diagnose yourr problem bad idle guide Link to comment Share on other sites More sharing options...
Guest PIP Posted November 11, 2008 Share Posted November 11, 2008 eeeeeeeeeeeeee markie link i love it......................keep the faith Link to comment Share on other sites More sharing options...
Guest hewy Posted November 11, 2008 Share Posted November 11, 2008 its just a bad case of idleitis. groan! Link to comment Share on other sites More sharing options...
Guest Rojar Posted November 11, 2008 Share Posted November 11, 2008 Fantastic info guys thanks... I'll give it a try when the weather is better.......... Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted November 12, 2008 Share Posted November 12, 2008 its just a bad case of idleitis. groan! How would you know ??? You have a CVH !!! :happy001: Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted November 12, 2008 Share Posted November 12, 2008 had that problem with mine and found a bottle of stp injector cleaner did the trick for about 6 months but dont follow instructions dont add to full tank just add to under 1/4 tank worked on mine Link to comment Share on other sites More sharing options...
