Guest banburycab Posted October 28, 2008 Share Posted October 28, 2008 hi all just wondering im wanting to upgrade my mk 4 cabbie front breaks to s2 turbo do you need to cange the mounting brakets as well as iv got some calipers and discs but no rs turbo mounting brakets . many thanks grant Link to comment Share on other sites More sharing options...
Guest eddie Posted October 28, 2008 Share Posted October 28, 2008 hello grant no you dont need to change the mounting brackets the s2 rs turbo discs and calipers just bolt straight on with no worries easy job with good benefits hope this helps you mate thanks eddie. Link to comment Share on other sites More sharing options...
Guest banburycab Posted October 29, 2008 Share Posted October 29, 2008 hi cant see that rst discs will fit under the xr3 mouting brakets as theres not room with the xr discs many thanks grant Link to comment Share on other sites More sharing options...
Guest eddie Posted October 29, 2008 Share Posted October 29, 2008 grant i fitted s2 rsturbo brakes and calipers to my xr3i cabby with no problems just bolted straight on so providing you definetly have s2 rs turbo discs and calipers there should'nt be a problem fitting them hope this helps thanks eddie. Link to comment Share on other sites More sharing options...
Guest orion88 Posted October 29, 2008 Share Posted October 29, 2008 straight swop altho if ur running decent power might be worth the cossie conversion Link to comment Share on other sites More sharing options...
Guest steelcabby Posted November 1, 2008 Share Posted November 1, 2008 you need to take the complete XR caliper unit off the hub, and put the complete RS caliper onto your hub. brake pipes are the same. hubs are the same. but slidders are different. XR mounting brackets are completely different to RS mounting brackets Mate Link to comment Share on other sites More sharing options...
