Guest jonnymac Posted October 16, 2008 Share Posted October 16, 2008 can anybody tell me the list of problems i would have if i were to fit a complete s2 RS turbo engine, boxand loom into a mark 3 xr3i cabriolet? I'm sure I used to know all this but this has been my first ford in years. Thanks Link to comment Share on other sites More sharing options...
Guest benny Posted October 17, 2008 Share Posted October 17, 2008 as i aware, the only prob is the loom, you should change over tanks, too, raditor, prob a few more things too, isnt the s2 a efi and the mk3 mfi? so you'd have to put the ecu in, as the mfi injection doesnt have one so to speak? after that think there pretty straight forward, both a cvh block Link to comment Share on other sites More sharing options...
Admin Paul Posted October 17, 2008 Admin Share Posted October 17, 2008 The S2 turbo is a MFI mate, the Fiesta Turbo was EFI Link to comment Share on other sites More sharing options...
Guest Alanman Posted October 17, 2008 Share Posted October 17, 2008 When I did it to ours there was a lot to change. I'm sure there was easier ways but the car was almost a shell when we was doing it. I changed everything right down to the petrol pipes. Are you changeing the dash to Mk4 too? I found a few problems when I did that. The speedo doesn't go through bulk head in the same place. Steering rack is different too IIRC. Luckily I had the donor car parked at the side. If I needed anything I just got it off the other one. The one thing I didn't count on, the Radiator and fan being different. I needed to cut my front panel to acomodate the fan. There's a lot to change but nothing that would be too much of a problem. ALanman Link to comment Share on other sites More sharing options...
Guest Alanman Posted October 17, 2008 Share Posted October 17, 2008 You can get anything to fit with a bit of persuasion and a grinder. Link to comment Share on other sites More sharing options...
Guest jonnymac Posted October 17, 2008 Share Posted October 17, 2008 I'm just looking at options, as S2 parts are easier to find than S1. Am i right in thinking the gearbox cradle is different too? Link to comment Share on other sites More sharing options...
Guest Eggsy Posted October 17, 2008 Share Posted October 17, 2008 I'm just looking at options, as S2 parts are easier to find than S1.Am i right in thinking the gearbox cradle is different too? you can keep the mk3 gearbox (fit an LSD) & uprate the antiroll-bars to S1 or 16i - engine will fit no problem the major diferences are the loom & piping for the turbo/ic etc. all my stuff in my mk3 is S2 but its mainly aftermarket ic's rads etc - & they where a bit of a pain in the rs Link to comment Share on other sites More sharing options...
Guest orion88 Posted October 21, 2008 Share Posted October 21, 2008 just get a s1 engine.loom and rad fan and intercooler easy:D Link to comment Share on other sites More sharing options...
Guest jay Posted October 21, 2008 Share Posted October 21, 2008 it can be done but not worth the hasstle in my opinion, why change? keep everything mk3 (series 1) im doing exactly that and have already sourced all the bits, check out "my mk3 se d plate" in show us yours! watch this space! Link to comment Share on other sites More sharing options...
