Guest hawkesy2k8 Posted September 11, 2008 Share Posted September 11, 2008 Hi All Will a rs turbo rocker cover fit a efi engine? and will the plastic air intake still fit the same or would i have to get a rs turbo intake pipe? Link to comment Share on other sites More sharing options...
Guest tobys73 Posted September 11, 2008 Share Posted September 11, 2008 hi mate the rocker cover will fit on the engine but i'm not sure about the air intake, if you need a pick to compare let me know as i got a turbo one lying in the shed i can take a pic of and post up Link to comment Share on other sites More sharing options...
Admin Paul Posted September 11, 2008 Admin Share Posted September 11, 2008 It would need to be a 90 spec RS Turbo rocker cover, else the mounts for the air intake will be to close together. On 90+ they are wider Paul Link to comment Share on other sites More sharing options...
Guest steelcabby Posted September 11, 2008 Share Posted September 11, 2008 or maybe get the fiesta turbo cover and charge carrier? charge carier is longer on the fiesta so the filter could sit further away. Link to comment Share on other sites More sharing options...
Guest hawkesy2k8 Posted September 12, 2008 Share Posted September 12, 2008 cheers for the replies. i was just having second thoughts on the charge carrier as my air box is on the left hand side Link to comment Share on other sites More sharing options...
