Guest Max Posted September 4, 2008 Share Posted September 4, 2008 hi all, im trying to get in contact wirth anyone on here who may be an auto electrician or know the wireing starter circuit for an xr3i. i have so many cut wires and joins i dont know what goes were, its all connected as it was when i got it so in theory it sould be correct but im having issues with turn over without going direct to the starter. if anyone here knows anything about it would be fantastic to hear from you. thanks in advance max Link to comment Share on other sites More sharing options...
Guest BionicSi Posted September 4, 2008 Share Posted September 4, 2008 Where abouts are you mate, I know an mobile auto electrican but he's in west yorkshire. Wheres you? Link to comment Share on other sites More sharing options...
Guest Max Posted September 5, 2008 Share Posted September 5, 2008 Where abouts are you mate, I know an mobile auto electrican but he's in west yorkshire. Wheres you? thanks for that but im a bit in essex, south east. guessing the call out charge would be a little steep Link to comment Share on other sites More sharing options...
Guest marcus Posted September 5, 2008 Share Posted September 5, 2008 Hi, Basic stuff 1.Large red wire direct from Battery, same place where this bolts onto Starter a smaller red wire will go to your alternator. 2. Trigger wire (normally blue) on Escorts will come from your ignition switch through a relay in your fuse box directly to you starter, this is the cranking part of the circuit, this can be found on the round black electrical switch at the end of your key lock on the steering colume, there will be other wire there as well !! but its easy to find the correct wire just buy turni9ng the key right the way round. If this car has had previous alarms fitted before its would be a fair bet to say this circuit has been cut into at some point so you might well just need to run another wire from the back of the switch to the starter.....but always use a relay or you might overload the wiring. It sounds a lot but its so easy What part of essex are you,if your near Harlow area i can recoomend a very good auto electrician......but be warned they are not cheap, you would expect to pay at least 100 pounds for a mobile visit. Steve. Link to comment Share on other sites More sharing options...
ianxr3i Posted September 5, 2008 Share Posted September 5, 2008 Whereabouts in essex are you mate. I could come round over the weekend to help you out. Link to comment Share on other sites More sharing options...
Guest Andy Posted September 5, 2008 Share Posted September 5, 2008 thats what its about lol nice one Link to comment Share on other sites More sharing options...
Guest Max Posted September 6, 2008 Share Posted September 6, 2008 cheers for all that guys, im in colchester, is that at all local to you? Link to comment Share on other sites More sharing options...
