Guest Webby1980 Posted July 27, 2008 Share Posted July 27, 2008 I've been having some hot starting probs, starts fine when cold but when hot just turns and turns and turns, to get it started I have to just touch the starter over if you know what I mean then turn over again then it starts but there are times when it can take ages. Have flattened the battery once doing this. Help!!! xxxxxx Link to comment Share on other sites More sharing options...
Guest sirgodrolo Posted August 2, 2008 Share Posted August 2, 2008 I've been having some hot starting probs, starts fine when cold but when hot just turns and turns and turns, to get it started I have to just touch the starter over if you know what I mean then turn over again then it starts but there are times when it can take ages. Have flattened the battery once doing this. Help!!! xxxxxx if its on a mk4 like ive got the starter sometimes gets cooked by the down pipe as its so near i made a heat shild for mine and its not to bad now only plays up now and then hope this helps Link to comment Share on other sites More sharing options...
