Guest Webby1980 Posted July 25, 2008 Share Posted July 25, 2008 Hi again! I have a problem with my drivers side window when it is fully up when I activate the switch the motor sounds but doesnt bring the window down I have to push it down say a quarter of the way then it works as normal up and down until it reaches that point again the the motor starts just turning and not moving the window so I have have to pull it up into the fully up position. the trouble is also it doesn't press onto the door seal and so is allowing water in. Will I need a new motor and reg or is this repairable? Help appreciated. x Link to comment Share on other sites More sharing options...
Guest cabbydaz Posted July 25, 2008 Share Posted July 25, 2008 sounds to me the teeth on the reg have buggered very common motor should be ok if it a mk5 i might have 1 lying around Link to comment Share on other sites More sharing options...
Guest SiV6Si Posted July 26, 2008 Share Posted July 26, 2008 Hi again! I have a problem with my drivers side window when it is fully up when I activate the switch the motor sounds but doesnt bring the window down I have to push it down say a quarter of the way then it works as normal up and down until it reaches that point again the the motor starts just turning and not moving the window so I have have to pull it up into the fully up position. the trouble is also it doesn't press onto the door seal and so is allowing water in. Will I need a new motor and reg or is this repairable? Help appreciated. x Same problem i had with my Mk 6 cabby, The regualtor is replaceable as the motor unbolts from it... Good luck finding another one, i had to buy 2 motors complete ( Removed from a mk 5 b as the mk MK5 b and MK 6 1's are the same ) Link to comment Share on other sites More sharing options...
Guest Kyle Posted August 1, 2008 Share Posted August 1, 2008 Any luck in finding parts for this? My MK6 drivers window has the same problem Link to comment Share on other sites More sharing options...
