Guest steelcabby Posted July 21, 2008 Share Posted July 21, 2008 HELLO, CAN ANYONE TELL ME HOW YOU GET THE IGNITION BARREL OUT OF A MK4 CABBY? SOMEONE WANTS THE LOCKSET AND I'M NOT SURE EXACTLY HOW TO DO IT. AND I DON'T WANNA BREAK THE OUTTER CASING TO GET IT OUT AS I'D RATHER KNOW HOW IT COMES OUT WITHOUT BREAKING IT OUT. HELP PLEASE Link to comment Share on other sites More sharing options...
Guest tonkerboy23 Posted July 21, 2008 Share Posted July 21, 2008 Hey mate from what i remember you put the ignition key in and turn it bout quarter of a turn and then keep moving it until the little pin on the side will move then it should just pull out hope this helps mate Link to comment Share on other sites More sharing options...
Guest lutonman12 Posted July 21, 2008 Share Posted July 21, 2008 dont you take the whole sleeve thingy thats over the steerin column out???unplug it undo the four bolts and take the lot out Link to comment Share on other sites More sharing options...
ianxr3i Posted July 21, 2008 Share Posted July 21, 2008 If you want the ignition barrel only, Turn the key to position 1 & there should be a little lever that you need a little screwdriver to push in. You should be able to withdraw the barrel. Link to comment Share on other sites More sharing options...
Guest gazzahgv Posted July 21, 2008 Share Posted July 21, 2008 If you want the ignition barrel only, Turn the key to position 1 & there should be a little lever that you need a little screwdriver to push in. You should be able to withdraw the barrel. The last barrel i took out you removed the steering column shroud then you undo the 2 bolts that hold the barrel in place but i think they were headless bolts. hope thats some help Apologies if its not Link to comment Share on other sites More sharing options...
Guest steelcabby Posted July 21, 2008 Share Posted July 21, 2008 i'll have another look tomorrow guys. it looked to me that there was a pin on top and you should push it down and twist it out?. i'll give both ways a try tomorrow and see what happens thanks for your replies Link to comment Share on other sites More sharing options...
Guest Max Posted July 21, 2008 Share Posted July 21, 2008 yeah should just turn the key a bit then push the little bit in like the earlier post said Link to comment Share on other sites More sharing options...
