Guest eddie Posted June 16, 2008 Share Posted June 16, 2008 hello everbody i have a f reg mk4 cabby which as been standing for a while i have just decided to sort it out get it re mot and taxed etc but i seem to have a problem with the brakes as they seem real spongey which i don't remmember them being like before it stood for a while can't understand why this as happened any help or advice would be great. second thing i would like to know is does an as escort rs turbo exhaust fit on an mfi non turbo engine without being modified, also i see quite a few of you have 17" alloys on your cabs does anybody know of any 17" alloys that fit without cutting out or rolling the rear arches any help with these questions would be grateful. thanks eddie. Link to comment Share on other sites More sharing options...
Guest markeyboy Posted June 17, 2008 Share Posted June 17, 2008 you may need to bleed the brakes to get all the air out, my mk4 had the bush where a vacume hose connects to the master cylinder was knackered, relpaced it (only about 3 quid from ford) sorted out the spongey ness and made it idle a little better too Link to comment Share on other sites More sharing options...
Guest sandman2209 Posted June 17, 2008 Share Posted June 17, 2008 u shud be able to put 17s on without cuttin m8 i got a set of 17s on mine but get as low a profile tyre that you can or ur budget will allow as mine did have sum rubbing on the rear arches but nothin major it was only wen goin over a big dip in the road or sumthin Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted June 17, 2008 Share Posted June 17, 2008 if your gonna bleed your brakes buy lotsa fluid and replace as it soaks up water and makes your brakes cr*p i change mine every time i buy a car Link to comment Share on other sites More sharing options...
Guest eddie Posted June 17, 2008 Share Posted June 17, 2008 thanks for the advice lads will check them thinks out and see what happens. Link to comment Share on other sites More sharing options...
