Guest daygo30 Posted June 16, 2008 Share Posted June 16, 2008 My escort was sitting for a year before i brought it and the previous owner said that the pump was over filled at some point and the plastic cap at the front broke off, i took it apart and put the seal on correctly and the plastic cap with level the right way LOL - then filled up with the correct oil, the pump worked slowly to start with, i left the filler cap off while i kept putting the roof up and down to get rid of the air bubbles then the pump got quieter and worked great. Then an hour later i tried the roof again and the pump was noiser and moving very slowly, i think it may be because there is air in the system. How do you correctly get air out of the system once you fill with fresh oil?? Any advice appreciated. Many thanks Link to comment Share on other sites More sharing options...
