Guest lukemk6cab Posted June 10, 2008 Share Posted June 10, 2008 hi all im new got my escort mk6 ghia 1996 cab in green last week for a bargain price of a grand mint interior,tiny bit of rust on back left arch mint hood and cover 90k on clocks with service history camelt done 5 k ago.couple of prblems though. 1.dodgy idle wen cold and not so bad when warm,ive just fuly servived it and got the right oil from ford,has sorted it abit.any ideas? 2.where can i get the cheapest set of bushes from? 3.after shocks and sprins 40mm drop? last thing where can i get the bit that covers up the wooden dash bit? any help would be much appreciated. Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted June 10, 2008 Share Posted June 10, 2008 hi all im new got my escort mk6 ghia 1996 cab in green last week for a bargain price of a grand mint interior,tiny bit of rust on back left arch mint hood and cover 90k on clocks with service history camelt done 5 k ago.couple of prblems though.1.dodgy idle wen cold and not so bad when warm,ive just fuly servived it and got the right oil from ford,has sorted it abit.any ideas? 2.where can i get the cheapest set of bushes from? 3.after shocks and sprins 40mm drop? last thing where can i get the bit that covers up the wooden dash bit? any help would be much appreciated. cheap doesnt mean good go for proflex last ages and think long and hard about lowering makes em very harsh (looks good though) cant always go round corners fast as bumps lose u traction imo that is good luck Link to comment Share on other sites More sharing options...
Guest steelcabby Posted June 15, 2008 Share Posted June 15, 2008 hi all im new got my escort mk6 ghia 1996 cab in green last week for a bargain price of a grand mint interior,tiny bit of rust on back left arch mint hood and cover 90k on clocks with service history camelt done 5 k ago.couple of prblems though.1.dodgy idle wen cold and not so bad when warm,ive just fuly servived it and got the right oil from ford,has sorted it abit.any ideas? 2.where can i get the cheapest set of bushes from? 3.after shocks and sprins 40mm drop? last thing where can i get the bit that covers up the wooden dash bit? any help would be much appreciated. Hi chap, i have a graphite grey dash surround to replace your wooden one, give me a buzz if you want pics also i would not go lower than 35-40mm on the suspension. i have always used G-MAX supersport kits which cost around 189.00 for the lot, very easy to change. its a good kit never had problems with it, coil-overs are just too damn expensive. as for the bushes i wouldn't bother with the standard ones, for straight in for proflex, and the full kits are really cheap. last a very long time and help keep things together, would be good to do the bushes and suspension at the same time. would also be good to change the front drop-links and front and rear top-mounts . your probably looking at around 350 pounds to do the lot, no point buying second hand crap. hope this helps Link to comment Share on other sites More sharing options...
Guest PIP Posted June 15, 2008 Share Posted June 15, 2008 never use cheepo stuff on ure cab mate Link to comment Share on other sites More sharing options...
