Guest malcolm Posted June 8, 2008 Share Posted June 8, 2008 Hi Bit of a newbie dumb question....... Have recently bought a 1990 (G) cabriolet, and have found now that the locked boot doesn't open. Key fits ok, so not sure what's next? Anyone out there any ideas? Link to comment Share on other sites More sharing options...
Guest stephc Posted June 8, 2008 Share Posted June 8, 2008 i had that on my mk5 1993 cabie in the end we had to clime in through the back seats and there is a boot relise on the in side and open it that way i had to have a new boot lock so it might be the same for you maybe worth givein it ago good luck steph Link to comment Share on other sites More sharing options...
Guest malcolm Posted June 8, 2008 Share Posted June 8, 2008 have you tried turning to the left as you look at it and the turn key back to 12 o'clock position then push it in Tried that, unfortunately didn't work, thanks anyway. Link to comment Share on other sites More sharing options...
Guest gotty Posted June 10, 2008 Share Posted June 10, 2008 Does the key turn in the lock ? Does the lock pop all the way out ? Mine if the lock hasnt poped all the way out it wont unlock even tho the key turns in the lock. Link to comment Share on other sites More sharing options...
Guest blackleb3 Posted August 11, 2008 Share Posted August 11, 2008 if your still having this problem how to open the boot would be drill throught the centre of the lock till you push the latch to open the door then never lock the boot again to replace the lock goto a scrap yard and ask for a sierra lock just by looking at it you can see if it fits before you buy Link to comment Share on other sites More sharing options...
