Guest jam Posted June 7, 2008 Share Posted June 7, 2008 Hi All I've got a mk3 cabbie (Carb fed) that has had a mk4 dash conversion done prior to my ownership. However the rev counter has never worked, I have tried to get this working by running a wire from the negative side of the coil, as I have done in the past with cortinas/capris and the like, however i cannot find a spare wire on the back of the clockset that connects to the rev counter. I have tried every wire i can find with some amazing results, but no working rev counter. I know that the clockset is from a later mk4, with the larger warning lights at the top. Hoping you guys might have some suggestions as I am at a loss Thanks http://www.escortcabrioletclub.co.uk/forum...icons/icon9.gif Link to comment Share on other sites More sharing options...
Guest Justin Posted June 8, 2008 Share Posted June 8, 2008 Ok, now im not entirely sure about this, so it needs confirming by someone else, but i think whereas the mk 3 ran the rev counter off the coil, i think the mk4 ran from the back of the gearbox or something.. Needs confirming by someone with a mk4 though.. Link to comment Share on other sites More sharing options...
Guest jam Posted June 8, 2008 Share Posted June 8, 2008 Ok, now im not entirely sure about this, so it needs confirming by someone else, but i think whereas the mk 3 ran the rev counter off the coil, i think the mk4 ran from the back of the gearbox or something.. Needs confirming by someone with a mk4 though.. Ok thanks for your reply. I will have another look today. I have read somewhere about it running from the alternator????. I am at a loss really. Link to comment Share on other sites More sharing options...
Guest SiV6Si Posted June 8, 2008 Share Posted June 8, 2008 The rev counter on both the mk 4 and mk 3 ran from the Coil, Not directly but they ran from the coil, The mk 3 ran from the Blue / Yellow / Green box that was located behind the centre speaker cover. Mk 4 ran it directly from the coil pack. It runs from the Negative side IIRC. Link to comment Share on other sites More sharing options...
Guest jam Posted June 9, 2008 Share Posted June 9, 2008 The rev counter on both the mk 4 and mk 3 ran from the Coil, Not directly but they ran from the coil, The mk 3 ran from the Blue / Yellow / Green box that was located behind the centre speaker cover. Mk 4 ran it directly from the coil pack. It runs from the Negative side IIRC. Thanks for your help in clarifying that for me. Now all i got to do is find the correct wire from the clockset ??????? LOL. Link to comment Share on other sites More sharing options...
