Guest drstride Posted May 28, 2008 Share Posted May 28, 2008 Can anyone please advise me on the type of fitting that a late Mk4 escort Xr3i Cab uses to secure the steering wheel to the column? Is it a splined Boss or a hexagonal fitting? Was it the same fitting for Mk3 escorts also? My original factory fitted steering wheel has the horn push in the centre. I would like to fit a 3 spoke Ford RS type wheel. Thanks & KR Steve. Link to comment Share on other sites More sharing options...
Guest cabbydaz Posted May 28, 2008 Share Posted May 28, 2008 hi m8 mk4 s are hexagonal fitting unless been messed with and had mk3 colum put in hope this helps Link to comment Share on other sites More sharing options...
Guest drstride Posted May 28, 2008 Share Posted May 28, 2008 hi m8 mk4 s are hexagonal fitting unless been messed with and had mk3 colum put in hope this helps ThanQ CabbyDaz very helpful, I can bid for it with confidence on e-bay now! Cheers for yer trouble m8. Link to comment Share on other sites More sharing options...
