Guest littlejohn Posted May 21, 2008 Share Posted May 21, 2008 hi has anyone resolved this problem,when ignition turned on the temp guage goes to bottom of the white marking and stays there even with engine running for 15- 20 mins the radiator fan doesnt come on even with the coolant bubbling away.I have tried a new sender unit but still the same I had the head gasket done a few months ago and replaced thermostat with a new radiator also. I have checked through forum and someone has had the same problem but there is no answer thanks for any help Scotty Link to comment Share on other sites More sharing options...
Guest markeyboy Posted May 21, 2008 Share Posted May 21, 2008 have ya tried bridging out the 2 pins of the temp sender plug (or stright to ground if ya only have one wire) and check to see if the gauge moves, i think ya can get fan switches that operate at diferent temps too, Link to comment Share on other sites More sharing options...
Guest littlejohn Posted May 21, 2008 Share Posted May 21, 2008 have ya tried bridging out the 2 pins of the temp sender plug (or stright to ground if ya only have one wire) and check to see if the gauge moves, i think ya can get fan switches that operate at diferent temps to thanks for that it must be some sort of wiring fault as it has started to work when out in it today,then when i was checking to see if fan came on it stopped again,after messing with wire it went to proper temp and fan cut in thanks again for ya reply Link to comment Share on other sites More sharing options...
