Guest trev Posted May 11, 2008 Share Posted May 11, 2008 hiya. had a bit of a fun swapping batteries over left right and centre the other day due to my alternator belt snapping, and I think ive blown the fuse for the central locking as its no longer working. Could anybody point me in the right direction as to where it is? as I cant seem to find it in the fusebox? thanks Link to comment Share on other sites More sharing options...
Guest SiV6Si Posted May 12, 2008 Share Posted May 12, 2008 hiya. had a bit of a fun swapping batteries over left right and centre the other day due to my alternator belt snapping, and I think ive blown the fuse for the central locking as its no longer working. Could anybody point me in the right direction as to where it is? as I cant seem to find it in the fusebox? thanks What year is your car Trev, MK 3 and MK4 never had a fuse IIRC ( if it did thou it would be under the clear plastic cover under the bonnet Left hand side ) MK 5 and MK 6 the fuse is numbered in the fuse box 20 AMP IIRC No30 ( or so the haynes manual says ) HTH Si. Link to comment Share on other sites More sharing options...
Guest trev Posted May 12, 2008 Share Posted May 12, 2008 heya, its ok its all sorted now, not quite sure what i did but after a fumble about with the relays/fuses and removing/checking them all....it has fixed itself. Excellent Link to comment Share on other sites More sharing options...
