Guest lutonman12 Posted May 5, 2008 Share Posted May 5, 2008 hi ive got a mk3 cab that has a late xr3i engine in it(mk4 cvh EFI)and my rev counter doesnt work !!is this because the mfi takes the revs from the dizzy???and ive got efi so NO dizzy???im not that bothered about it but if its an easy fix i might as well do it eh?? Link to comment Share on other sites More sharing options...
Guest lutonman12 Posted May 5, 2008 Share Posted May 5, 2008 any ideas??? Link to comment Share on other sites More sharing options...
Guest 6tracy9 Posted May 5, 2008 Share Posted May 5, 2008 I'm not 100% but the revs could be picked up from the flywheel on the EFI? Link to comment Share on other sites More sharing options...
Guest lutonman12 Posted May 5, 2008 Share Posted May 5, 2008 can u elaborate?? Link to comment Share on other sites More sharing options...
Guest 6tracy9 Posted May 5, 2008 Share Posted May 5, 2008 Not really!!! LOL!!! thats what hubby just told me!!! i'll see if i can find out! Link to comment Share on other sites More sharing options...
Admin Paul Posted May 5, 2008 Admin Share Posted May 5, 2008 You can take a wire from the edis unit directly to the rev counter, will try and find which colour you need Link to comment Share on other sites More sharing options...
Guest lutonman12 Posted May 5, 2008 Share Posted May 5, 2008 is the edis the small ecu?? Link to comment Share on other sites More sharing options...
Admin Paul Posted May 6, 2008 Admin Share Posted May 6, 2008 Edis lives in the engine bay on N/S inner wing Paul Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted May 13, 2008 Share Posted May 13, 2008 (edited) Hi, Take a good look at the back of your alternator for a terminal marked as "W", if it has this terminal on it, which it should, then connect your rev counter wire to this and it will work perfectly.... hope this helps........ Edited May 13, 2008 by Cabbytech Link to comment Share on other sites More sharing options...
Guest lutonman12 Posted May 14, 2008 Share Posted May 14, 2008 cool when u say hook it up to my rev counter not sure wot u mean?? Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted May 15, 2008 Share Posted May 15, 2008 The rev couter has a green signal wire, that picks up a pulse to make the rev counter work, you need to find the green wire from the rev counter and either wire it to the "W" terminal on the alternator, or alternatively, you can wire it to the edis unit, i believe its pin 18 on th edis unit, hope this helps...... Link to comment Share on other sites More sharing options...
Guest lutonman12 Posted May 15, 2008 Share Posted May 15, 2008 CHEERS THATS A BIT CLEARER!!! ILL LET YOU KNOW HOW I GET ON Link to comment Share on other sites More sharing options...
