Guest Max Posted May 2, 2008 Share Posted May 2, 2008 Hi all, i have just recieved an F reg XR3i cab and want to test the engine is good. It has arrived with no fuses, anywere..... Also no fuse box cover...... relays are in but i have no idea what fuses i need or which slots to put them in!!!!! anyone got a MK4 XR3i they could look at and list fuse/position for me? help muchly appreciated. Thanks in advance Link to comment Share on other sites More sharing options...
Guest tonkerboy23 Posted May 2, 2008 Share Posted May 2, 2008 Right from left to right 5 10 10 15 30 10 10 20 30 15 20 30 20 25 25 10 15 20 25 IGN MAIN DIP SIDE HEADWASH MAIN DIP SIDE HEATREAR MAIN2 IND WINDOW INTLIGHT INJ FAN BRAKELITE HAZ FAN WIPER Hope this helps Link to comment Share on other sites More sharing options...
Guest Max Posted May 2, 2008 Share Posted May 2, 2008 cheers for that, i seem to have power now, lights horn etc. now it seems i have an immobilizer, it clicks when i turn the ignition. problems with this are..... i have a very thin black wire that goes nowhere i have a small connector with nothing to connect it to and i have no keys/fob. the car interior is in bits no dash/door cards seats or anything fitted so i'm using a screwdriver to turn the ignition. anyone got any ideas how to fix/bypass the immobilizer to just get her started? Link to comment Share on other sites More sharing options...
