Guest SiV6Si Posted April 20, 2008 Share Posted April 20, 2008 Hiya guys i'm currently wiring in a boot release switch ( as found in the Hard top version ) So far i have fitted the actuator and loom BUT i can't seem to find any reference to the Boot switch ( i.e. what wires do what ) I've looked in both versions of Haynes manuals and also searched the Internet. If anyone has fitted this before your assistance would be greatfully apreciated. Many thanks Si... Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted April 21, 2008 Share Posted April 21, 2008 I have one mate, I used the live from the boot light as its perminant, I also used the negative from it too but you can use the boot lid its self if needs be !!! Link to comment Share on other sites More sharing options...
Guest SiV6Si Posted April 21, 2008 Share Posted April 21, 2008 Thanks for that but what i should of asked is , The boot release switch - which pin is the feed to the solinoid ? Link to comment Share on other sites More sharing options...
Guest markeyboy Posted April 21, 2008 Share Posted April 21, 2008 (edited) i may be wrong on this but if it had 4 pins, 2 will be for the illumination and 2 will be the actual switch. if ya have a multimeter or somthing simular set it to read ohms or audio bleep setting and test across the pins the illumination should give you a constant bleep or an ohm reading the switch should give you nothing untill the switch is pressed once identified i dont think it matters wich side you connect to +12 and what side to the solenoid, it should work all the same hope this helps mate Edited April 21, 2008 by markeyboy Link to comment Share on other sites More sharing options...
Guest SiV6Si Posted April 21, 2008 Share Posted April 21, 2008 Thanks once again guys. Link to comment Share on other sites More sharing options...
Guest ste Posted April 21, 2008 Share Posted April 21, 2008 On the boot switch it runs a negative pulse to the alarm/central locking module,behind the cover in drivers footwell. from there it then sends a positive pulse to the solenoid, via the white with green stripe wire on the plug nearest the door. hope this helps you Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted April 21, 2008 Share Posted April 21, 2008 (edited) Oooops, sorry mate lol, I have 4 leccy windows and an isolation slide on my controls so no boot relese button !!! :wow: I used a Mk4 Festa Switch and it has four pins, two for the illumination and two for the release button like Markey said !!! I added a Red LED but it was for the Old Cab, swapping it with a White one for the New one !!! Edited April 21, 2008 by ESCORT-X4GC Link to comment Share on other sites More sharing options...
Guest SiV6Si Posted April 27, 2008 Share Posted April 27, 2008 Ste, the wireing on the boot release switch is Brown, Brown Green, Brown Blue, Brown White. Not what i was expecting to be honest. So i take it if the wiring loom is in the car for the boot release then Hopefully the rest will be there. just i can't find the loom for love nor money... Link to comment Share on other sites More sharing options...
Guest ste Posted April 27, 2008 Share Posted April 27, 2008 (edited) Ste, the wireing on the boot release switch is Brown, Brown Green, Brown Blue, Brown White. Not what i was expecting to be honest. So i take it if the wiring loom is in the car for the boot release then Hopefully the rest will be there. just i can't find the loom for love nor money... you seem to have a strange loom in your car what year/model is it i have looked at the ford tis and there are 2 colour codes for tailgate switch upto 95 is brown(earth), brown(earth), brown/white(to control unit), brown/yellow(illumination), from control module to solenoid is white/red(12v live) from 96 is black(earth), black(earth), black/red(to control unit), black/orange(illumination), from control module to solenoid is white/green(12v live) wiring goes from switch in centre console to the dash picks up earth and illumination. then over to the central locking control module in the drivers footwell, this has 2 plugs the left one contains inputs, the right hand plug is the outputs. And this has the live feed to tailgate solenoid it runs down the drivers side sill up near the rear seats and into the tailgate via the grommet. i may have over looked something in the diagrams but i don't think i have, hope this helps. Edited April 27, 2008 by ste Link to comment Share on other sites More sharing options...
Guest SiV6Si Posted April 27, 2008 Share Posted April 27, 2008 you seem to have a strange loom in your car what year/model is iti have looked at the ford tis and there are 2 colour codes for tailgate switch upto 95 is brown(earth), brown(earth), brown/white(to control unit), brown/yellow(illumination), from control module to solenoid is white/red(12v live) from 96 is black(earth), black(earth), black/red(to control unit), black/orange(illumination), from control module to solenoid is white/green(12v live) wiring goes from switch in centre console to the dash picks up earth and illumination. then over to the central locking control module in the drivers footwell, this has 2 plugs the left one contains inputs, the right hand plug is the outputs. And this has the live feed to tailgate solenoid it runs down the drivers side sill up near the rear seats and into the tailgate via the grommet. i may have over looked something in the diagrams but i don't think i have, hope this helps. No that is pritty much spot on, What Year of TIS have you got ? mine doesn't show MK 6 wiring .... Link to comment Share on other sites More sharing options...
Guest SiV6Si Posted April 28, 2008 Share Posted April 28, 2008 (edited) Ste, I owe you a big Pint M8, I finally got it wired in today and delocked the boot in the process. Edited April 28, 2008 by SiV6Si Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted April 29, 2008 Share Posted April 29, 2008 Happy days mate, nice one !!! I will be sorting the Mk6 one out soon but i'll keep the lock as its integral to the chrome trim, DOH !!! Link to comment Share on other sites More sharing options...
Guest ste Posted April 29, 2008 Share Posted April 29, 2008 congrats on getting it done, my tis is the 2004 version Link to comment Share on other sites More sharing options...
