Guest streetwolf Posted April 20, 2008 Share Posted April 20, 2008 L reg mk5 was running when i pulled it in the garage a month ago come to it two weeks ago but wouldn't start had a bit of sun so pushed it out the garage to work on it a bit ,it still wouldn't start had a few alarm immobilizer probs but used to always start then the door packed in opening when alarm button was pressed on the key fob, with having no locks or door handles i couldn't leave it out side so brought it in back in garage not running to rip all the alarm and immobilizer out and put back to standard so now Ive rip the wires out and join them back to were they are meant to be but car still not start so i look deeper into it today and found that Ive got spark on all plugs (found one broke but still sparking) and it seems to have petrol as you can smell it so as it stopped running b4 i took alarm out and still not running now I'm scratching my head fuel cut of don't no were it is has it got a button you can reset ? (the fuel pump is priming) :icon_cry: i think its fuel as it goes to fire very slightly most mornings but could b my dodgy wiring wot you think any help plz or just someone to point me in the right way wood really be a help Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted April 20, 2008 Share Posted April 20, 2008 Hmmm. the fuel cut off reset button is under the cover down to the right of the accelerator pedal, you should see a red button on top of a little black box..but if you can hear the pump priming, its unlikely to be that... Above the reset button, there should be a relay, usually green, this is part of the ford built in immobiliser, and they can suffer from damp, it could be this relay may need replacing, could be worth a try.... Let us know how you get on..... Link to comment Share on other sites More sharing options...
Guest Dazzaas Posted April 20, 2008 Share Posted April 20, 2008 give it a squirt of easy start through inlet side see if it starts then stops as soon as its run out if so u gotta fuel prob Link to comment Share on other sites More sharing options...
Guest streetwolf Posted April 21, 2008 Share Posted April 21, 2008 give it a squirt of easy start through inlet side see if it starts then stops as soon as its run out if so u gotta fuel prob tryed didnt start also found the reset button theres a gap witch im thinking the red button pops up from when needed but carnt see the red button so thinking its not that going to look at relays now so will let you no Link to comment Share on other sites More sharing options...
Guest streetwolf Posted April 22, 2008 Share Posted April 22, 2008 thxs lads check all that you put so as i had spark and could smell fuel i went for it took spark plugs out rested them on cover turned it over and flames came out so scratched my head again and thought time to go get the Haynes so grab the manual and thought ill just grab so new spark plugs can't hurt having new plugs gets home put them in turn the key and yup started first turn man do i feel stupid but on a good note at least i can start putting it back together and Ive got rid ov all the messy wiring/alarm/mobilizer so can get the new one in so happy dayz thxs again Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted April 23, 2008 Share Posted April 23, 2008 Great news mate, i'm glad the beast lives again, got any new pics of your hard work mate !!! Link to comment Share on other sites More sharing options...
