Guest edy Posted April 19, 2008 Share Posted April 19, 2008 hi, sorry to bother you all again but could anyone tell me how to adjust the springs on my mk4, i have been told that it has koni adjustable springs at the moment lowered to 60mm and the ride is harsh so i want to take it up a little. cheers Link to comment Share on other sites More sharing options...
Guest rs-steve Posted April 20, 2008 Share Posted April 20, 2008 edy on the top of the dampers should be little tabs sticking up and should have arrow pointing left and right sayin soft or hard Link to comment Share on other sites More sharing options...
f40 cab Posted April 20, 2008 Share Posted April 20, 2008 ok 2 things if its height you want to adjust, that will be on the suspension strut under wheel arch should have thread on strut, if its the stiffness you want to adjust then as said this is done from in engine bay top of strut should have a tool to screw the top. Link to comment Share on other sites More sharing options...
Guest edy Posted April 20, 2008 Share Posted April 20, 2008 ah, thanks both, there is a bit of tinkering and messing around to be done then to get it right, should be a bit of fun, cheers both Link to comment Share on other sites More sharing options...
