Guest DJB29 Posted April 18, 2008 Share Posted April 18, 2008 hi there to all i`m wondering if anybody could help me out.i saw the wiring diagram which simon had done in the power roof conversion guide which i had found it very useful but i still need which wires in which numbers on the 5 way relays must be plugged in ? someone please help this is driving me mad Link to comment Share on other sites More sharing options...
Guest Spannerman Posted April 18, 2008 Share Posted April 18, 2008 Here's what I think are the relay connections: pin 30 to the pump pins 85 and 87a to ground pin 87 to +12v(permanent live I believe) pin 86 to the switch. both relays are wired the same way, one makes it go up and one down which does what will depend on how you connect it at the pump end so if the switch sends it the wrong way swap those connections over. Don't forget to use fuses in the 12v feeds. DISCLAIMER: I think this is right, but check it properly before you connect it up. I am not responsible for any smoke, burnt out cars or anything else really, the value of your investment may go up or down, your haouse is at risk if you do not keep up payments, and all the other usual rubbish you get in the small print. Link to comment Share on other sites More sharing options...
Guest DJB29 Posted April 18, 2008 Share Posted April 18, 2008 Here's what I think are the relay connections: pin 30 to the pump pins 85 and 87a to ground pin 87 to +12v(permanent live I believe) pin 86 to the switch. both relays are wired the same way, one makes it go up and one down which does what will depend on how you connect it at the pump end so if the switch sends it the wrong way swap those connections over. Don't forget to use fuses in the 12v feeds. DISCLAIMER: I think this is right, but check it properly before you connect it up. I am not responsible for any smoke, burnt out cars or anything else really, the value of your investment may go up or down, your haouse is at risk if you do not keep up payments, and all the other usual rubbish you get in the small print. (on the diagram looks like both pump wires go to the earth) Link to comment Share on other sites More sharing options...
Guest Spannerman Posted April 18, 2008 Share Posted April 18, 2008 Hopefully cleared that up in the shoutbox just now Link to comment Share on other sites More sharing options...
Guest sjc Posted April 18, 2008 Share Posted April 18, 2008 the drawing is to wire the pump from scratch, thats not a drawing of the loom or the way factory fitted pumps are wired as theres no saftey interlocks or igniton on feeds, although it will work. Lower 12v feed should deffinately be fused as spannerman says. Link to comment Share on other sites More sharing options...
Guest DJB29 Posted April 19, 2008 Share Posted April 19, 2008 thanks for help everyone now sorted with electric roof after having owned the car for 14 years with a manual 1 ,have to give it bit of a push to make it go down. Link to comment Share on other sites More sharing options...
