Guest mk5rs2k Posted April 17, 2008 Share Posted April 17, 2008 Hi i am having trubble bleeding the brakes on my cab. i have fitted rs2000 brakes in the back and 4x4 cosworth in front. there is only fluid comming out and i have to step on the pedal 3 times before the brakes grabs the disc. is it any special about the abs system on the front wheels that i have to do to make the brakes work?. sorry for my bad grammar the reason is that i'm from norway Link to comment Share on other sites More sharing options...
Guest Michael Tomlinson Posted April 17, 2008 Share Posted April 17, 2008 Do you have Bosch ABS if you do you have get the valves moving in the module to allow the fluid to pass through it to calipers,slam on the brakes while driving then blle them.Used to use a thing called a bleed esay which pulses the abs module so the valve go up and down,Try a pressure bleder as well.Also have you got a load valve on the brake system as these can get blocked. Hope this helps Michael Link to comment Share on other sites More sharing options...
