Guest ragarse Posted April 15, 2008 Share Posted April 15, 2008 went to look at a mk4 cabby, guy tells me fuel pump is duff, no noise when key is turned, but its an efi engine and i am not sure if the efi pump is different to the mfi as this is the only one i have had. noe i have looked on ebay as you do and the only one i can see it says it goes in the petrol tank is this right or is that just the sender? as all the mk4 cabs i have had the fuel pump is strapped underneath. please help. thanx in advance. Link to comment Share on other sites More sharing options...
Guest benny Posted April 15, 2008 Share Posted April 15, 2008 every one ive seen yeah its been underneath at the back, not in the tank, have you checked the relay first, really easy way to check if the pump is working, connect a wire to the battery, then touch the live if it wurs the relay is bust new realy, job done, if not, there about 78quid ish, dead eady todo just watch the bracket doesnt fall to peices! Link to comment Share on other sites More sharing options...
Guest lutonman12 Posted April 15, 2008 Share Posted April 15, 2008 every one ive seen yeah its been underneath at the back, not in the tank, have you checked the relay first, really easy way to check if the pump is working, connect a wire to the battery, then touch the live if it wurs the relay is bust new realy, job done, if not, there about 78quid ish, dead eady todo just watch the bracket doesnt fall to peices! efi escort s have got the pump in the tank,they ve also got a cut off switch in the boot (a button on the top of the spare wheel holder thingy!!)check its pushed down sometimes they go off over speed humps etc its a cut off switch for the pump!! Link to comment Share on other sites More sharing options...
Guest benny Posted April 15, 2008 Share Posted April 15, 2008 not all,i broke one a few years ago and that was underneath? Link to comment Share on other sites More sharing options...
Guest lutonman12 Posted April 15, 2008 Share Posted April 15, 2008 not all,i broke one a few years ago and that was underneath? mmmmmmm ??may have been converted to efi (like my mk3)mine is underneath just thought it was mentionin cos if its acting like the fuel pumps f@@@ed it may just be the cut off switch ??best thing to do is have a look underneath and see wot its got ,id say??!!! Link to comment Share on other sites More sharing options...
Admin Paul Posted April 15, 2008 Admin Share Posted April 15, 2008 all efi are in the tank mfi bolted underneath Link to comment Share on other sites More sharing options...
Guest lutonman12 Posted April 15, 2008 Share Posted April 15, 2008 all efi are in the tank mfi bolted underneath the boss has spoken lol!!!! Link to comment Share on other sites More sharing options...
Guest benny Posted April 15, 2008 Share Posted April 15, 2008 okay sir! forgot some mk4 were mfi lol ill buy you a drink end of the month Link to comment Share on other sites More sharing options...
Guest ragarse Posted April 16, 2008 Share Posted April 16, 2008 (edited) thanx a lot for your input fella's much appreciated. now i need to know where the relay is so i can check this if anyone knows & secondly where abouts on the tank is this thing situated top bottom or side? & what it looks like & how much am i looking at getting one for? & last of all is it a bugger of a job to do? thank you for your help! forgot to add will a mk5 one fit it? p.s the switch in the boot is depressed so i am informed. thanx again! Edited April 16, 2008 by ragarse Link to comment Share on other sites More sharing options...
