Guest mitch121 Posted April 12, 2008 Share Posted April 12, 2008 Hey guys brought some doors from NO2LURCH great doorsno rust nothing!! onli prob cant work out how to fit them lol!! the onli way i can see to do it is by takin the wholle dashboard out!! is this really what i need to do?? thank mitch Link to comment Share on other sites More sharing options...
Guest steelcabby Posted April 12, 2008 Share Posted April 12, 2008 (edited) on the mk4 hinges, there are E-clips that you need to slide off, and the pins knock up as far as i know. then this will release the door but get this checked. i think the mk5 have screws in the side to release the doors. check for a head on the pins. they may unscrew, but i think they knock out Edited April 12, 2008 by steelcabby Link to comment Share on other sites More sharing options...
Guest mitch121 Posted April 12, 2008 Share Posted April 12, 2008 Whooooops forgot to put it on a MK4 Cab !! lol Link to comment Share on other sites More sharing options...
Guest steelcabby Posted April 12, 2008 Share Posted April 12, 2008 after you said lurchs doors. i knew anyway. get some pics of the hinges so we can check for you. unless you have done it already Link to comment Share on other sites More sharing options...
Guest mitch121 Posted April 12, 2008 Share Posted April 12, 2008 after you said lurchs doors. i knew anyway. get some pics of the hinges so we can check for you. unless you have done it already Will put some photo's on 2night if i get a chance wont be doing doors till Wednesday as that is my next day off lol!! thanks for ure help will try and get done if i can find camera lead for PC!! mitch Link to comment Share on other sites More sharing options...
Guest ANDYA Posted April 12, 2008 Share Posted April 12, 2008 Door removal MK4. 1. Open the door fully and support its lower edge on a jack or blocks, cover with a cloth to prevent damage. 2. Unscrew the 2 bolts that attach the check arm to the body, and disconnect the arm. 3. Remove the scuff plate from the sill at the bottom of the door opening. 4. Unclip the lower cowl trim panel and radio speaker, careful this is fragile, take your time. 5. You may need to remove the heater duct to improve access to hinge bolts. 6. Disconnect wiring multi plug if central locking, electric windows are fitted. 7. Unbolt the lower hinge from the body pillar, careful, its easy to drop the bolts into the cavity! 8. On the MK 4 you can't easily reach the upper hinge bolts due to the dash. You will need to extract the pin from the upper hinge assembly. There is a special tool for this 41-018 but you can make one with a u shaped cut out that will engage under the head of the pin. A large flat head screwdriver can be adapted for this. Strike the tool downward at the bottom of the pin,to remove the pin. When refitting, tap the pin upwards into place. When refitting, dont full tighten the lower hinge bolts until the door is correctly aligned. They can be tightened from inside when all is ok. Hope this helps, assistance will make the task easier. Andy Link to comment Share on other sites More sharing options...
Guest Eggsy Posted April 12, 2008 Share Posted April 12, 2008 if you take your clocks out the top hinges on o/d are reachable Link to comment Share on other sites More sharing options...
Guest steelcabby Posted April 12, 2008 Share Posted April 12, 2008 thought it would be easier to remove the door from the hinges rather than removing the hinges with the door. lining it back ups gonna be a pain in the ass Link to comment Share on other sites More sharing options...
Guest ANDYA Posted April 12, 2008 Share Posted April 12, 2008 Steel, I don't think it's an option with the lower hinge, the pin doesn't come out, and it's only an option on the upper because the dash makes it very difficult to reach the hinge bolts. You're right tho', it is a pig of a job! Andy Link to comment Share on other sites More sharing options...
Guest steelcabby Posted April 12, 2008 Share Posted April 12, 2008 oh ok, fair enough. complete pain in the ass......lol Link to comment Share on other sites More sharing options...
Guest mitch121 Posted April 12, 2008 Share Posted April 12, 2008 right so which way is the easyest lol!! Link to comment Share on other sites More sharing options...
Guest lutonman12 Posted April 13, 2008 Share Posted April 13, 2008 right so which way is the easyest lol!! i ve found takin the dash out easiest cos the top pin is a ba****d to do !!!! Link to comment Share on other sites More sharing options...
Guest mitch121 Posted April 13, 2008 Share Posted April 13, 2008 Lol ok ok..... Ive had a plan ill do one door one way and the otherone the other way the i will post which is easyer!! lol hmm will need a sunny day thou garge aint big enough to take doors off lol! Link to comment Share on other sites More sharing options...
Guest steelcabby Posted April 13, 2008 Share Posted April 13, 2008 sounds good to me mate. do a proper guide for the site. and get it on a sticky Link to comment Share on other sites More sharing options...
